Hide A Support Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 10:29 PM   #1
Hide a support beam
Tearing a supporting wall down. Someone suggested hiding the beam in the attic to keep the ceiling flush with the other room.?
handyman60 is offline   Reply With Quote
Old 05-17-2012, 10:56 PM   #2
So what are you asking?
Can this be done?
In some cases, yes in others no. You'd have to ask an engineer if this is an option for you. It's more of a pain to do, but if you have enough help it really isn't too bad.
HalfHand is offline   Reply With Quote
Old 05-17-2012, 11:17 PM   #3
Rewards Points: 328
I had that done years ago. Carpenter needed to add a dormer to the roof there the beam rested on the outside wall. Yes it was more trouble but it worked out fine.
puttster is offline   Reply With Quote
want lowest profile load-bearing support beam (removing wall) rpk7309 Building & Construction 2 05-17-2012 07:48 AM
Large hole in wooden support beam a problem? mephisto Building & Construction 5 07-18-2011 11:36 AM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 07:06 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 11:03 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 06:36 PM
