HEY! Heavy SLATE Floor Tile As An Exterior Wainscot - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 07:26 PM   #1
HEY! heavy SLATE floor tile as an exterior wainscot
Recently I have seen two homes with slate tiles for exterior wainscot.
Frankly, it looked really good.
why is this not used more often? real and fake stone products are common on exteriors. slate is relatively common on roofs- why not exterior walls?
drbabs is offline   Reply With Quote
Old 07-02-2011, 07:50 PM   #2
DIY staff
Rewards Points: 7,174
It's a style that is currently popular---remember the sand stone from the 60s?
Just wait,tie dyed shirts and bell bottoms will be back!
Old 07-02-2011, 07:52 PM   #3
besides style though. this stuff runs 2-4 bucks a foot where manufactured stone and brick veneers run 4-10.
is adhesion an issue?
this house is 4 years old and looks ok so far
Old 07-02-2011, 07:53 PM   #4
Rewards Points: 5,336
Many slate products will not work well in a wet environment. They are soft and delaminate.
You need to pick a slate, up to the job.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (07-02-2011)
Old 07-03-2011, 07:02 AM   #5
Rewards Points: 4,794
ron's exactly right - slate is a product of sedimentation & resultant compression,,, as a result, its susceptible to delamination from freezing intrusive water ( don't even ask if there's a product to prevent this - there isn't ! )
slate is also comparatively soft & has little compression OR tension strength.
Old 07-03-2011, 07:42 AM   #6
Tom Struble's Avatar
Rewards Points: 2,002
they better stop using it for roofs then
Tom Struble is offline   Reply With Quote
Old 07-03-2011, 08:37 AM   #7
slate roofs ( known as 100yr roofs ) use a quality product far better than what's commonly purchased today,,, IF buyers knew quality slate, they wouldn't buy the **** now being sold at apron/vest stores,,, you'd rarely find that quality spec'd in any architectural building - residential OR commercial,,, its largely disappeared from roofs due to replacement by less expensive materials,,, roofing slates are also installed with 1/3rd reveal - NOT a full exposure as shown by the op
Old 07-03-2011, 11:20 AM   #8
Rewards Points: 1,014
Absolutely untrue. Slate is the resultant product of metamorphism ( read heating and pressure combined) of a fine grained sediment. The result is a entirely new rock from the protolith, with an entirely different crystal structure of its constituents.
It is commonly composed of mica and micaeous minerals, elongate amphiboles such as hornblende, quartz and feldspar. It is the middle rock of the metamorphic continuum of progressive metamorphism of a shale parent, shale - phyllite - slate - schist. The mineralogy would not be susceptible to absorption of water, and the structure would also tend to shed water.
It would be possible for water to enter cracks and interstices in the rock, and if this was followed by freezing, the spalling and other modes of failure could result.
The statement by the OP at ContractorTalk of the presence of natural oils in slate is also completely false. Metamorphism would evaporate any and all volatiles contained in the matrix.
Anti-Wingnut
Construction Management and Geologist
BS Geol and Graduate Studies
Last edited by Anti-wingnut; 07-03-2011 at 08:58 PM. Reason: one little misspelled word
Anti-wingnut is offline   Reply With Quote
The Following 3 Users Say Thank You to Anti-wingnut For This Useful Post:
Evstarr (05-02-2012), Tom Struble (07-03-2011)
Old 07-03-2011, 02:08 PM   #9
ok, we have 20 year old slate on the floors of a hunting cabin lots of hot anc cold . no problems there at all. so cheap slate can go on floors, but for roofs and exterior stuff there must be a higher grade of slate. "frost resistant" i think is the term for outdoor applications. I am curious about the sealing of a slate product as I have seen slate on shower ceiling applications.
how about normal ceramic or porcelain floor tiles? High compressive and tensile strength, no lamination issues. Totally water fast. How would this do for an exterior wainscot when installed properly?
Old 07-04-2011, 06:14 AM   #10
ok - ok - OK, wing ! ! ! so i sits corrected a walk thru any cemetery will reveal delaminating slate monuments which, i theorize, would not occur IF slate were more dense or homogenous,,, it is precisely why granite is chosen for monuments over slate, marble, concrete, common stone, etc,,, i don't recall if slate has a ' grain ' but granite does
no scientific data but do rely on experience in our family's cemetery monument biz ( over 100yrs ) + repairs to many slate/marble monuments,,, IF we were to choose slate, my choice would be pa's pen arglyll or vermont verde,,, enjoy your day ! thanks for the post, too !
Old 07-04-2011, 11:05 AM   #11
How often do you see ceramic tiles on exterior walls? I've seen them now and again and thought, "Why would you do that?" I would think you would need something a little more visually diverse and significant. Veneer stone over tiles would be a more substantial choice.
Ron
B. Franklin 1759
Old 07-04-2011, 11:24 AM   #12
Anti-Wingnut
BLINK BLINK......
wow. I asked for a cheese snack and you baked me a wedding cake!
ok, so in laymans terms. what is you opinion about installing slate on exterior walls, assuming the proper underlayment and proper flashing etc.
thanks for everyones opinions here.
Old 07-04-2011, 12:13 PM   #13
BLINK BLINK......
It would need to be a higher grade of slate, not the soft earth tone stuff sold ay the big box stores. Espesially if you're in a freeze zone.
Ron
B. Franklin 1759
Old 07-04-2011, 04:14 PM   #14
Exterior slate wall tiles are a common finish detail on commercial jobs. As was stated by others, there are grades which are perfectly suitable for exterior use. The big stores sell by price point. Seek out a reputable contractor and architect if needed to ensure that the section of wall is built correctly, all the way back to the ply wood and rain screen if needed
Old 05-02-2012, 03:50 PM   #15
how do you make sure slate stick to the wall . I am installing slate on my front prouch and i need to put some on bottom of the wall below the floor . what should i do make shure it dosn't fall off thanks
Dave
dharring is offline   Reply With Quote
Tags
exterior , masonry , siding , tile , wainscot
slate walls timbo59 Building & Construction 5 12-06-2010 09:46 AM
Slate tile Termite Flooring 14 04-01-2010 09:05 PM
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 04:59 PM
Slate Tile... Jshakour Flooring 13 04-24-2008 10:34 PM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 04:23 PM
