Help With Water Main Seal Leak! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 06:43 PM   #1
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Help with water main seal leak!
Well we have gotten now about 5 inches of rainfall in my area since yesterday with no signs of stopping. I went down to the basement to work on it tonight and noticed something very upsetting. Just below the main water pipe there is a wet area. It seems to leech down the wall about 4-5 inches. Its obviously very slow but its there and its the first time I have ever noticed it.
There seems to be some black stuff around the pipe, im guessing they just drill a rough hole through the foundation on install and fill it with some sealent stuff?
What should I do? I have no idea how to fix this but obviously can't finish that wall area with the leak, at the current state its minor but everyone knows how water is!
Thank you very much!
-Mark
Taipans is offline   Reply With Quote
Old 03-18-2008, 07:43 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
When you have leaks, you should try the easiest, reasonable solution first (Because it sometimes works).
Thus:
Try Hydraulic Water Stop Cement:
http://paint-and-supplies.hardwarest...nt-198051.aspx
- Build Well -
Old 03-18-2008, 09:06 PM   #3
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Thus:
I will give that a try, so I just smear it on around the brass pipe? Thanks as usual Atlantic!
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 07:20 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 06:34 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
leaking water main LanterDan Plumbing 4 08-31-2006 08:24 AM
