Help! Water Coming From Boiler Room Wall In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2014, 11:32 AM   #1
Help! Water coming from Boiler Room Wall in basement
Hey Guys
Just moved into a home, and it seems every time we run the sprinklers, there seems to be some water coming in to the basement.
What should we do? Who do we call - A contractor? An Engineer?
Im a noob so i have no diea
Help! Water coming from Boiler Room Wall in basement-image.jpg   Help! Water coming from Boiler Room Wall in basement-image2.jpg
omienice is offline   Reply With Quote
Old 07-31-2014, 11:56 AM   #2
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Does your house have a skirt drain system? What this does is direct water away from foundation and basement and drain it away from the house. If you have an existing skirt drain it may be blocked.
Gregg M.
gmaint is offline   Reply With Quote
Old 07-31-2014, 11:57 AM   #3
I'm not sure we do. Any way we can find out?
Old 07-31-2014, 12:39 PM   #4
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Do your downspouts go into the ground? If they do it is likely that your house has a skirt drain. If they just have deflectors at the bottom you don't.
Either way with a basement you need a skirt drain system.
Gregg M.
Old 07-31-2014, 01:14 PM   #5
Oh yes! We have the spouts going in to the ground. Any way to clear them/check them?
Old 07-31-2014, 01:25 PM   #6
And is there a professional i should contact?
Old 07-31-2014, 02:56 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
A plumber can scope the downspouts drains and see if they are clogged.
Pictures from the exterior will help here.
The Following User Says Thank You to Windows on Wash For This Useful Post:
gmaint (07-31-2014)
Old 07-31-2014, 03:12 PM   #8
joed's Avatar
Rewards Points: 11,972
The first image looks like a crack. You might be able to fix it by getting epoxy injected into it.
The second image looks like the concrete form ties. BEST fix is to dig the outside and seal the problem areas. the install a proper drainage board to drain the water to the foundation perimeter drain(weeping tiles).
In the mean time stop squirting your sprinklers so close to the house. Or at least turn the timer shorter so you have less water being applied.
Tags
basement , repairs , water
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Sump pit keeps filling, can't see water coming in ks-man Plumbing 30 12-31-2014 06:32 PM
Water leaking into basement over foundation wall? Kern1 Concrete, Stone & Masonry 12 10-21-2013 10:37 AM
Water coming in under basement door lucaduc General DIY Discussions 3 07-28-2011 07:48 PM
Basement faucet- Hot Water not coming out SpringfieldMike Plumbing 8 01-24-2009 09:42 AM
