Help With Tub Surround Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 06:35 PM   #1
Solutions (handyman)
Rewards Points: 362
Help with tub surround installation
The tub surround installation sounds easy, ... except the mobile home walls are not plumb. How best to install the tub surround? Raise the back and sides until they all meet ate the seams or shim the walls where I can? Any suggestions would be appreciated. It is a three piece Lyon's "Classic" 3060 tub surround.
Mark Harvey is offline   Reply With Quote
Old 10-31-2011, 08:15 PM   #2
DIY staff
Rewards Points: 7,174
Any way to Sister in some wood to plumb the walls?
That will be a mess if the the tub is fastened to the studs and the walls lean in or out---
Old 10-31-2011, 08:50 PM   #3
Rewards Points: 362
Not sure, I'll look tomorrow. It may be possible or ... what about shims?
Old 11-01-2011, 07:06 AM   #4
DIY staff
Shims should work well---you need to get the corners right---the 'wing walls' can be distorted a bit without a problem----
Old 11-01-2011, 09:55 AM   #5
Rewards Points: 6,652
Mark, can you post pictures showing how far out of plumb the walls are? Keep in mind, that the tub needs to sit, so that water will flow towards the drain, and not sit. As for the walls, it could just be that the trailer is out of plumb, not the walls. How long has it been sitting in the same spot, and are there actually footings under the blocks that it is sitting on, or just sitting on dirt, that may have washed out or moved.
Old 11-01-2011, 11:06 AM   #6
Rewards Points: 362
Tub Surround
Sorry, no to the pictures, just in a rush to get this done. The out of plumb isn't too bad but I'd like it to be "almost perfect". The trailer is about a 1972 model and was recently purchased. It was re-levelled about a month ago ... this is why I think it's the walls. The tub (new) is level in both directions. Any suggestions are always welcome. Thanks,
Old 11-01-2011, 11:18 AM   #7
If it is that old, there is no doubt that the flooring is bad, the walls have bowed, due to the roof shifting. Mobile homes built that early used 1x3 for the roof and walls, and were not very sturdy.
Old 11-01-2011, 03:11 PM   #8
Rewards Points: 362
Thanks Guys, The job is almost done, ... looks okay. Between some shims and strapping I got it reasonably plumb. It does sit nicely on the tub and the two corners (where the seams are) fit fairly well. I think I will also add some extra white silicone at the base and on the seams. The "instructions" don't mention this but a little extra makes sense. Appreciate all the comments. Mark
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 07:30 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 11:52 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
