HELP!!!!....Stucco Is Falling Apart - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 09:07 PM   #1
NJE
HELP!!!!....Stucco is Falling apart
Hello all
Not sure if this is the right catagory. I am having a problem with the stucco that is on the outside of my home. From some reason, it has started to crack and come apart in this once specific area of the house...I have attached pictures.
I am not what to do at this point. What caused the issue and how do i fix it?
Thanks for your help!!
HELP!!!!....Stucco is Falling apart-picture1.jpg   HELP!!!!....Stucco is Falling apart-picture2.jpg   HELP!!!!....Stucco is Falling apart-picture3.jpg   HELP!!!!....Stucco is Falling apart-picture4.jpg
NJE is offline   Reply With Quote
Old 03-19-2009, 08:13 AM   #2
Rewards Points: 5,336
You need to supply some details. Was the surface painted before the stucco was applied? Is that dark spot a hole? Discoloration? How long has the stucco been up? Where do you live? Cold climate?
Looks like water damage. Has it occured any other place?
Ron
Old 03-21-2009, 03:41 PM   #3
NJE
I am not sure what was done when the stucco was applied...I bought the house 3 yrs ago and the stucco was already on. The house is old....about 80 yrs....
As for the climate, I live in NJ.....This basically started to crack at the end of last summer and got worse through the winter...
That is the only place where it has cracked like that....how do i diagnose and fix?
Old 03-21-2009, 03:44 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
probably had some frost heave under the driveway
Tom Struble is offline   Reply With Quote
Old 03-22-2009, 10:27 PM   #5
NJE
How do I fix it?
Old 03-28-2009, 01:32 PM   #6
NJE
Any suggestions guys?
Old 03-28-2009, 10:31 PM   #7
Rewards Points: 95
Is the dark spot a hole? If so that may be your problem. If the crack started in the summer it was not due to freezing but that may be why it got worse over the winter. Once the crack was there it allowed moisture in and froze, popping off more stucco. Your house looks like a house around the corner from me.
NJ Brickie is offline   Reply With Quote
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
Mounting Hose Reel on Stucco Siding xquercus General DIY Discussions 5 07-03-2008 12:00 AM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
