Help Something Is Wrong. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 01:01 PM   #1
Unhappy
Help something is wrong.
We installed this brick surround for our freestanding wood stove but when we applied the polycrilic to the base this is what happened. We have tried to use muratic acid on it again we even attempted to sand off the poly thinking it might be what was discoloring it. HELP???? How do we fix it?????
msmanda is offline   Reply With Quote
Old 11-12-2012, 01:19 PM   #2
isn't polycrilic for wood?
maybe some citristrip and some 3M pads.
Old 11-12-2012, 01:47 PM   #3
Architect
Rewards Points: 150
polycrylic is for wood, not brick.
http://www.minwax.com/wood-products/...tective-finish
Based on research it looks like you are going to have to strip it off.
Don't use sandpaper as going through the coating you applied will abrasive the brick affecting the surface texture.
jcarlilesiu is offline   Reply With Quote
Old 11-12-2012, 01:57 PM   #4
We used it on the walls and it turned out fine. But i will try to strip it and see what happens. How do I protect the carpet?
Old 11-13-2012, 06:30 AM   #5
Rewards Points: 1,596
a dropcloth?
bob22 is offline   Reply With Quote
Old 11-13-2012, 11:01 PM   #6
Rewards Points: 24
Just because you used it on the walls and it "worked" doesn't mean it was a good idea. What made you use it in the first place? Guess I don't see why you would even want to.
ponch37300 is offline   Reply With Quote
Old 11-14-2012, 03:04 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Minwax® Polycrylic® Protective Finish is a crystal clear, ultra fast-drying protective topcoat for use on interior wood surfaces including furniture, trim, doors, cabinets and paneling.
Right on the can
chrisn is online now   Reply With Quote
Old 11-14-2012, 05:46 AM   #8
DIY staff
Rewards Points: 7,174
I think she (or he) is talking about Customs grout from the Depo---that is Poly something----
Brick is not glazed like tile---so the grout got into every nook and cranny----(a sealer would have made this easier to clean)then you did not finish cleaning off the grout---you should not have walked away from that until the brick was clean---
If muriatic acid did not get that off----you will need to remove the brick and start over.
Old 11-14-2012, 06:39 AM   #9
Rewards Points: 29
That pad area looks awful small. I suggest you verify the stove type and required clearances to combustibles. Also are the walls in the back ground real brick, veneer or some sort of fake brick paneling. Unless they are real brick you are unlikely to have proper clearances.
MarkusAIC is offline   Reply With Quote
Old 11-14-2012, 06:42 AM   #10
It's all real brick.
Old 11-14-2012, 09:27 PM   #11
Rewards Points: 24
So what was it that you used? Polyurethane that is for wood or poly grout like someone mentioned?
Electrician estimates-how wrong are they allowed to be? eli99 Electrical 22 03-15-2012 09:40 AM
IS this wrong? Romex connector? JeepNick Electrical 27 02-29-2012 10:30 AM
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 10:42 PM
Staining project - Did I do something wrong - Need help. family_man Painting 4 11-03-2011 01:10 AM
2 handle shower wrong direction Lisa C Plumbing 7 07-24-2011 09:28 AM
