Help Removing Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 05:02 PM   #1
I want to remove the subfloor made of 3/4" T&G plywood that's glued and nailed to sleeper floor joists. I want to be able to save the joists, but its proving quite difficult just to remove the subfloor.
Any suggestions?
Also, there are non-load bearing walls sitting on the subfloor. What's the best way to work around that. just cut the subfloor up to the wall?
acerunner is offline   Reply With Quote
Old 09-08-2010, 05:33 PM   #2
kwikfishron's Avatar
Rewards Points: 428
You can cut up to the wall. You may have to add a joist or blocking for the new sub floor.
For the rest you can cut out the plywood in-between the joist and work on the rest with a sharp chisel, Sawzall and a nail puller, what ever it takes.
kwikfishron is online now   Reply With Quote
Removing subfloor nickdu Flooring 3 07-28-2009 08:34 AM
Removing old thinset from subfloor gburg3 Flooring 3 12-15-2008 07:59 PM
Removing Ceramic tile from subfloor Gerry Kiernan Flooring 4 06-06-2008 08:55 AM
Removing damaged bathroom subfloor icandoitmyself Flooring 3 10-23-2007 08:50 AM
Removing Subfloor, Leveling and install new.... dcd22 Building & Construction 5 07-13-2007 07:59 AM
