HELP Reinforce A Cracked Rafter - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 04:08 PM   #16
I plan to sister the splitting 2x6 rafter with another 2x6 - the entire length of the rafter from joining point to garage wall. Is that ok or will plywood be better?
Wolfen is offline   Reply With Quote
Old 02-22-2011, 04:47 PM   #17
In the first photo is the rafter tie really sagging that much, or is that lens distortion?
pyper is offline   Reply With Quote
Old 02-22-2011, 05:06 PM   #18
Should I drive the screws slanted at a certain angle, or just straight 90 degrees into the wood?
Old 02-22-2011, 05:59 PM   #19
the main thing is to get the two pieces tight together. Then try to screw in as straight as you can. If you can't go in straight, switch to a slightly longer screw
mrgins is offline   Reply With Quote
Old 02-22-2011, 06:52 PM   #20
Thanks mrgins - I'm getting closer.. Is my decision to sister the full length of rafter ok (same exact length and dimensions, ie 2x6) or should I just cut maybe 3 or 4 feet length? Just to cover enough the splitting part..
Old 02-22-2011, 09:02 PM   #21
Rewards Points: 956
cant you just sister some plywood to each piece to reinforce it? nevermind thats what other people said too
federer is offline   Reply With Quote
Old 02-23-2011, 10:56 AM   #22
That too I'd go with a 3/4" strip of cdx, glued and screwed, with shorter screws obviously
Old 02-23-2011, 11:05 AM   #23
Thanks for all your suggestions, I'm very pleased. I'm gonna be busy this weekend with all these new knowledge ;-)
My action plan: I will first glue the split wood together and drive a 4" screw diagonally from the bottom, 1 screw every six inches apart. That should help the glue keep the split wood stick together better.
As to the sister, I'm torn between using an 11 ft 2x6 to match the entire lengh of the troubled rafter, or just use a 4ft plywood on one side. Care to provide more info on why one is a smarter choice than the other, or does it even matter?
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 10:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 11:40 AM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 03:02 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 06:03 PM
