Help Please: Drip Edge Overhang - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2013, 07:18 AM   #1
Help please: drip edge overhang
Hi everyone. We just had our house reroofed. After it's done, noticed the shingles run flush with drip edge with no overhang. What should I do since everything's done? What are the consequences by leaving them like that?
Also the roofer put nails on the lower skylight flashing pan which doesn't need any. Thanks for your responses!
trjones is offline   Reply With Quote
Old 09-14-2013, 08:33 AM   #2
Rewards Points: 14,026
Read though some of the older post under roofing.
It can rot out the sheathing, fascia, run down behind the fascia into the soffits and run back in the house and take out the sheetrock.
Nails in the flashing in the wrong place can cause water leaks on the inside.
These are all roofing 101 mistakes and never should have happened with any roofer that knows what there doing.
Find them on Angies list by any chance?
Old 12-05-2013, 03:01 PM   #3
Originally Posted by joecaption View Post
It can rot out the sheathing, fascia, run down behind the fascia into the soffits and run back in the house...
Agreed, with regard to the shingles position to the drip edge.
Not a quick fix after the entire roof has been installed.
Do you know the manufacturer / model skylight that was installed?
You may be able to re-flash the skylight fairly easily.
Was the contractor recommended to you via a referral site or company that offers workmanship guarantees (Home Depot or Lowes...)?
usbp.josh is offline   Reply With Quote
Old 12-05-2013, 07:08 PM   #4
Simple and best answer would be right on the manufactures web site on install directions.
Drip edge, etc. Will this be OK? jklingel Roofing/Siding 4 11-28-2012 11:36 AM
Should installed drip edge cover fascia board? dilerin Roofing/Siding 12 11-04-2012 02:03 PM
Question about metal roof on shed and drip edge genEus Roofing/Siding 8 09-30-2012 09:27 AM
Gutters leaking with drip edge. Help! hansmike Roofing/Siding 6 10-10-2010 06:02 AM
Painting Fascia, should I paint the drip edge? PaulR Painting 3 12-19-2008 04:59 PM
