Old 01-25-2008, 12:09 PM   #1
Help with new cracks in textured walls
Hi,
I moved into my house in Virginia just over a year ago. The house is 9 years old. The walls and ceilings are all textured with a swirl pattern. In the last few weeks I have noticed some cracks appearing around the windows and in the corners where the walls meet. Around the windows it appears the the material they used to texture the walls is separating away from the wall. When I chip away the loose material there is not a crack in the wall behind it. Is this common? Can the quick changes in the weather cause this? Its been warm then real cold, then warm. As I look around the house it seems that the previous owner must have repaired some of these before.
I had the house inspected before purchasing it and there were no indications of any foundation problems.
Any advise would be greatly appreciated.
Giants2112 is offline   Reply With Quote
Old 01-25-2008, 02:46 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,......
My Guess is,....
The coating is separating from the drywall due to changing Temps,+ Humidity.......
Poor Preparation before it was painted on could also possibly be a contributing factor......
Old 01-25-2008, 06:04 PM   #3
Bondo is correct. The individual who applied the texture probably should have sealed the wall before application, especially if the area is prone to high humidity. But, I think you may have a deeper problem than just texture.
Is the house insulated? Do you know if it has a vapor barrier or house wrap?
If you're getting temperature fluctuations in your wall that are enough to cause condensation, you could eventually have a problem with mildew.
Randell Tarin is offline   Reply With Quote
Old 01-25-2008, 08:23 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Also, check the insulation in those areas. Specifically around the windows. It is very common, when windows are not properly insulated between their frames and the rough openings, for the drywall to crack from the extreme temperature change of the very cold cavity and the walls.
- Build Well -
Repairing Hairline Cracks in Plaster Walls jerome8283 Painting 8 11-17-2011 08:43 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Anything to keep in mind with painting textured walls? Shpigford Painting 4 10-18-2007 12:22 AM
Cracks in basement cemet walls avalon General Discussion 3 08-21-2007 06:28 PM
Repairing cracks in plaster walls BlueGuy Carpentry 4 07-24-2006 01:44 PM
