Help Mounting A Main Breaker Panel-- - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 03:16 PM   #1
Help Mounting a main breaker panel--
I am going to install a new 200a main service panel (overhead service)for my 1940's home. SCE approved the new location on my exterior garage wall. (currently 60a service- 4 breakers inside my kitchen) and i pulled the permit with the city.
I would like to semi flush mount the panel for better finish, but it's a stucco on framing home(no plywood) and i can't seem to figure out how to properly mount/weatheproof the panel into the stucco with the nailing flanges. (has 2x4 framing with exposed studs on the interior wall).
So, I'm thinking surface mount for easier install, with unistrut channel but it doesn't look like there's enough eaves to go through and mount a flashing. just enough to get in the way of the overhead mast( about 3 inches). any ideas??
Attached pic of the rear of my garage with location marked in orange.
Mast will end up just about the peak of my roof (plus 30 inches). Any help is greatly appreciated.
socalsteve72 is offline   Reply With Quote
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 08:28 PM
Distance between the main breaker panel and a manual transfer switch panel jerryallie Electrical 2 09-01-2010 09:11 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
