Help...Mold In New Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 08:44 AM   #1
Help...Mold in New Construction
We're just finishing up building a new house that we started last September. It's just been sitting with house wrap on the exterior walls waiting for warmer weather to brick it. I pulled some insulation away from the exterior wall in the unfinished walkout basement and there's mold. The water is soaking into the house wrap, seemingly through the staple holes, and wetting the osb. I'm not worried about this happening once the brick is on, but I need to get this dried out and mold removed. How big of a deal is this and how do I remedy it? Thanks in advance.
Hawkeye Country is offline   Reply With Quote
Old 04-09-2013, 08:49 AM   #2
Roofmaster
Rewards Points: 2,172
What makes you think that water does not go through brick? Sorry, it does.
Old 04-09-2013, 08:51 AM   #3
Rewards Points: 12,840
I hardly think a few staple holes is causing that much water coming inside.
Got some pictures of the outside?
Were all the seams taped?
Old 04-09-2013, 08:58 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Water coming in is usually the result of poor flashing and construction.
How about some pictures?
Old 04-09-2013, 09:07 AM   #5
Sorry, I don't have pics right now. The seams were not taped, but there are no vertical seems, only horizontal and they're overlapped. This was done by the framing contractor who has a reputation for building quality, fairly high-end houses, so I presume he hasn't had this issue before. I guess I'll have to talk to him about it. Is the mold easy to get rid of?
Also, the mold spots are not near windows or other openings, just tall exposed walls.
Edit: I talked to the contractor and he said it happens the first winter if there's no brick because frost gets on the walls and comes through. He said it's no big deal, pull insulation out to dry it out and spray it with bleach. Thoughts?
Old 04-09-2013, 09:45 AM   #6
Rewards Points: 880
Brick is veneer in this case and nothing from the structural wall should be touching the brick.
No moisture transference at that point if there is no contact.
Are their weep/vent holes on the brick?
Pulling out the wall and insulation doesn't address what caused the issue in the first place and I still suspect it is a bulk moisture issue as compared to a humidity/frost issue.
Old 04-09-2013, 09:52 AM   #7
Currently the brick isn't on the wall, they are just starting to brick it as we've had a cold spring, and haven't gotten to this wall yet. Perhaps I wasn't clear in my original post. Where they did start the brick it's not touching the wall so I don't forsee a tranfer of moisture from brick to framing.
Old 04-09-2013, 12:12 PM   #8
Rewards Points: 626
so it has been sitting there since september? and you do know that the house wrap is only good for 90 days exposed right? you do know that your to use the tar flashing tape on all the sheathing seams right? and why are you having insulation in the walls before the exterior is done? because your not dried in. you need to dry in your home first before really working on the interior.
Nailbags is offline   Reply With Quote
Old 04-09-2013, 12:55 PM   #9
No I didn't know that. It's pretty common around here the start a house in the fall, finish the inside throughout the winter, and brick in the spring. There are a couple other houses in the area going up the same way right now. What is the preferred practice when starting a house in the fall when its too cold to brick?
Old 04-09-2013, 01:08 PM   #10
Rewards Points: 744
Bleach doesn't kill mold.
http://www.jpmoldcontrol.com/faq/why...ach-work.shtml
http://www.normi.org/articles/bleach-mold.php
I use Concrobium or Sporicide.
Seattle2k is offline   Reply With Quote
Old 04-09-2013, 01:45 PM   #11
Rewards Points: 880
Originally Posted by Seattle2k View Post
+1
Common misconception.
It does do a pretty good job of interrupting the growth cycle but it does not render mold completely dead.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Nailbags (04-09-2013)
Old 04-09-2013, 08:11 PM   #12
Rewards Points: 626
I am not a mason so I have no clue to brick laying. I just do hardi plank siding and call it good. but yes pull out the insulation and dry out the area and use a fungicide or sporicide to kill the mold Good luck with your project and hope it helps.
Old 04-09-2013, 10:22 PM   #13
Roofmaster
Brick is not a barrier wall, and has to be installed as a water-managed system, where water is allowed to go through the brick and mortar, run down the back of the brick, hit a flashing and exit out of the system through weep holes. Proper flashings and end dams have to be provided above all openings like windows and doors, and at brick ledge. Correcting Improper construction of brick veneer walls is extremely expensive, so I suggest you get yourself educated real quick.
The Following User Says Thank You to jagans For This Useful Post:
Windows on Wash (04-09-2013)
Old 04-09-2013, 11:37 PM   #14
Registered User
Rewards Points: 4,914
It sounds like moisture from the basement air is condensing on the "first condensing surface" cold enough; http://www.buildingscience.com/docum...bout-diffusion
I'd talk to the builder about using some rigid foamboard, at least on the sunny-side;http://www.buildingscience.com/docum...n-brick-veneer
Per code, you are good with the ventilated air-space to the future brick, but remember, code is "minimum"- like a passing "D" in school; http://www.buildingscience.com/docum...r-requirements
The drainage plane behind the brick veneer; http://www.buildingscience.com/docum...d-wall-systems
You will continue to get mold on the inside of sheathing without a vapor barrier/retarder/air-tight drywall as f.g. is air/vapor permeable (think furnace filter), degree depends on location, where are you, in general?
Gary
Old 04-10-2013, 02:04 AM   #15
Rewards Points: 626
hey thanks good to know thanks for sharing.
Hello All, little help with basement mold problem? :) markaj311 General DIY Discussions 18 02-14-2013 05:27 PM
mold on subfllor jigijunk Flooring 11 02-20-2012 02:14 PM
Black mold on underside of plywood in addition.... tomwalla General DIY Discussions 28 02-12-2012 11:57 PM
Best way to clean mold? Pics included amodoko Plumbing 0 11-23-2011 12:46 PM
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 08:03 AM
