Help On The Mix Ratio For Stucco Brown Coat - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2009, 10:15 PM   #1
help on the mix ratio for stucco brown coat
hi, doing some stucco work. scratch is on. plastic cement and sand r bought. now, some say use lime with it some say not needed. so if i do or don't how many shovels of each material do i use? help. live near san diego if that matters thanks tom
tnttom25 is offline   Reply With Quote
Old 05-15-2009, 09:48 AM   #2
Old School
Willie T's Avatar
Some good reading for you....
http://architecture.about.com/librar...f-stucco04.htm
Willie T
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Cracked Brown Coat Not Sure Building & Construction 10 09-23-2006 05:40 AM
