Help With Metal Building Add-on - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 12:16 PM   #1
wooddoc
Help with metal building add-on
I have an existing new metal building 32 X 64 with 12 ft walls and a 4/12 pitch metal roof with a 1 foot overhang. I had the contractor pour a 12 X 20 slab with J bolts in the appropriate places on one of the long wall sides. My plan is to add a lean-to addition attached to the existing building with the new roof tied in just under the 1 ft. overhang, and sloping down to a 9 foot tall wall. My question is this:
I have never worked with this type of corregated metal before (the ribs are raised about an inch every 9" on center), so how do I go about attaching the framing to the existing wall? I would prefer not to remove any metal if possible. Can someone advise me of how to tie in to this existing structure?
wooddocinc is offline   Reply With Quote
Old 01-30-2008, 10:44 PM   #2
General Contractor
joasis's Avatar
More information would be needed to even begin to address this question.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 01-31-2008, 12:50 PM   #3
wooddoc
Ok, What else?
I am looking for help here....what other kind of info do you need to get me pointed in the right direction. This lean-to addition is just going to be used as a storage area. I know all about the roof pitch, the correct metal gauge, the framing will be different than building it is being attached to though, the existing building is pole barn construction with 9 foot poles, and 2 X 6 girts every 2 feet on the 12' walls. The lean to will be stick built frame of 2 x 6's with a service entry door and a window. I know how to frame the walls and roof, I just am not sure how to attach it to the corregated metal skin correctly. Do I tie it into the top plate girt, and just notch out for the raised ribs? Any info would be appreciated.
Old 01-31-2008, 02:20 PM   #4
General Contractor
joasis's Avatar
That was enough. If you are "tucking" the lean to under the existing overhang, which I would not do, you can start with blocking a header, or cutting 6 inch long blocks to attach to a full 2X6 3 feet on center...drill the blocks to prevent splitting and drive small lags into the existing building....then work out.
If you asked me to do this, we would frame off the rafter line, even if there is a pitch change, and lap the lean to roof under the roof panels, re-shooting the fasteners in the same holes, and I would simply match the existing framing exactly. That would be the correct way to do this.
The metal you are describing is a "classic" profile of panel, 9 inch ribbed 3/4 inch high with 2 low ribs. The blocking I described would "nest" between the ribs and bring a full header out to attachment.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Painting a metal building. okinawap Painting 5 01-19-2011 11:43 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
metal building vapros Building & Construction 2 10-01-2006 08:14 PM
kit metal building as addition structure weaver Building & Construction 9 08-08-2006 10:59 AM
