Help With Massachusetts Stair Code, Please! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 02:28 PM   #1
Help with Massachusetts Stair Code, please!
I had a friend help me months ago frame out a bathroom upstairs in my barn. Everything had to be cheated a certain way to make room for certain hallways, etc...
What I'm left with, is a very small area with which to build a staircase.
I will be building it with a landing and a 90 degree turn.
I've crunched all the numbers and all the possible rise/run figures over and over.
THe way I calculate that I can fit in a staircase without cutting into the doorway, are as follows:
11 runs at 10" per run
12 rises at 8 7/16" per rise.
I'm pretty sure the run is within code, but not sure about the rise. The existing stairs are about 9 7/16 rise, so it will be an improvement, at least, but I'd like to try to build them to code.
There is simply no alternative but to make my hallway upstairs illegally narrow by taking out a joist and moving the whole staircase further in.
I tried calling the building inspector today but he's out. Also didn't want to get grilled as to where I am, do I have a permit, etc...?
Thanks.
wombosi is offline   Reply With Quote
Old 02-17-2009, 04:33 PM   #2
Chicago, IL
Michael Thomas's Avatar
IRC R311.5.3.1 The maximum riser height shall be 7-3/4 inches...
- www.stairways.org/pdf/2006%20Stair%20IRC%20SCREEN.pdf
Home Inspection: ""A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Michael Thomas is offline   Reply With Quote
Old 02-17-2009, 06:26 PM   #3
Are you rebuilding/repairing existing stairs?
Is so then in some cases you are grandfathered
But usually if you are rebuilding the inspector will want you to meet current code
Given the option, keeping the landing space/hallway area is usually preferred
Old 02-17-2009, 07:24 PM   #4
Old School
Willie T's Avatar
No way you can make that landing turn 180 instead of 90? That way, 14 treads would be a breeze.
Willie T
Old 02-17-2009, 08:56 PM   #5
Well,
I pulled apart the upper landing earlier and moved it back 12". This leaves a true 36" hallway up top, and will allow for a 7 3/4 rise, and an 11" run.
Solved.
Questions:
is a 36" staircase width measured end of tread to end of tread, or it the width INSIDE the railings (or in my case, between the finish skirtboard and the inside of the railing?)
Likewise, i measured the 36" leaving room for drywall, but calculated right to the end of the floor, and NOT to inside the railing, however wide that will be, not sure.
Thanks.
Old 02-17-2009, 09:25 PM   #6
Chicago, IL
It's in R311.5.1:
Again, see http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf , it will make all this much clearer.
Old 02-17-2009, 09:41 PM   #7
Old School
Willie T's Avatar
He couldn't see the Stairways.org site earlier... the first URL was bad.
Willie T
code details for boxes kama Electrical 6 01-30-2009 11:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
