Help With Loft Bed Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 04:36 PM   #1
Rewards Points: 24
Help with loft bed construction
I plan to build what you might call a triple-loft bed. I've attached a drawing. The loft would fit into 2 corners of my kids' bedroom. The plan is to use:
- 2x6 doug fir, attached to the walls (studs) where possible
- 4x4's for the ladder, notched to support the 2x6's
- 2x2's + 1x6 slats + 3/4" plywood for mattress support
My questions are:
- how should I attached the 2x6's along the walls? Lag bolts? What size? Will these FastenMasters work - http://www.fastenmaster.com/product....tID=8&prodID=9
- How should I attach the 2x6's where they meet as circled in the drawing? Lags through one 2x6 into the end of another? How about angle brackets on the inside?
- Will 2x6 doug fir comfortably span the 78 3/16" shown? Should I use 2x8's instead?
- Is the cantilivered corner OK? - the distance to the 4x4 post is 19"
- Is the mattress support OK?
I'm also interested in any other suggestions/advice anyone might have. Thanks.
File Type: pdf triple bunk bed (revised 2010-11-04).pdf (19.0 KB, 96 views)
jjeglbs is offline   Reply With Quote
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
Help with loft bed construction burntdawn Carpentry 19 09-23-2011 09:40 PM
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 06:40 PM
workshop loft help needed Chrissy Building & Construction 1 10-02-2008 05:45 PM
How would i finish this loft???? (pics) oregonrebel Building & Construction 3 03-31-2007 09:01 AM
