Help Hanging Heavy Punching Bag From Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2007, 08:17 PM   #1
Help hanging heavy punching bag from ceiling
I recently bought a punching bag and am hanging it from my basement ceiling. I'm not sure of the weight, but I think its around 80lbs. Right now I have it hanging on a chain connected to a screw with a hook on the end. This hook is connected to a two inch thick board that is screwed into the ceiling with two big screws. The problem is everytime I hit the punching bag, it creaks throughout the whole house(and my house is not old, and usually doesn't creak). I can't do it in the night or morning, because it wakes up my family. How could I hang this from the ceiling so that it doesn't creak the house when punched.
chrisski1991 is offline   Reply With Quote
Old 03-14-2007, 09:25 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Realiize that you really need a proper swivel mount:
http://www.karatedepot.com/bag-mounts.html
An interesting article pertaining to your question:
http://www.doityourself.com/stry/steelceilingbeam
Last: You might want to consider laying a section of 2x12+ or a section of equivalent LVL horizontally (flat) across 2 ceiling joist members. Attach these with small diameter lag screws to the ceiling joists.
(I am not a pro installer of punching bags...But I am basing this on common knowledge weight support and building structure...and the fact that my wife has a punching bag mounted in the basement that she uses to workout on.... because it hurts when she hits me )... she was into self-defense before we even met ...
- Build Well -
Old 03-14-2007, 10:43 PM   #3
Cool
There are going to be vibrations, regardless. Is this bag connected to a spring?
Sounds like you need to lay off the bag and get into the ring!
overkill is offline   Reply With Quote
Old 03-15-2007, 06:14 AM   #4
Rewards Points: 150
Why not build a stand for it so then it won't be connected to the house?
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-15-2007, 02:50 PM   #5
Thanks for all of the advice. I think I might try building a stand.
Old 03-15-2007, 07:46 PM   #6
if you don't want to/cannot build the stand, i see them all the time at sporting retail stores for around $60-$100.
Mr. Michael is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 11:21 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
heavy ceiling light suspension amakarevic Building & Construction 1 07-01-2007 07:32 PM
Hanging heavy pictures in an old house BlackRichard Carpentry 4 05-07-2006 08:35 PM
