Help On Garage Concrete Floor! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2014, 03:27 PM   #1
Help on Garage Concrete Floor!
Hello,
I am currently debating what to do with my garage concrete floor. It is in not the best shape I would think (not much experience). There are cracks, one spot where concrete heaved and one spot where the concrete settled down.
So far my idea is to patch the cracks and then painting it properly...
Any ideas or tips?
Thanks a lot !
Phil
Help on Garage Concrete Floor!-garage-floor-1.jpg   Help on Garage Concrete Floor!-garage-floor-3.jpg
phirr14 is offline   Reply With Quote
Old 02-24-2014, 03:40 PM   #2
Rewards Points: 13,270
Filling the cracks is just going to crack again the next time it flexes again.
Old 02-24-2014, 04:13 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
How purdy do you want to make it?
Old 02-24-2014, 04:25 PM   #4
It doesn't have to be perfect, something that is an improvement to its look now...
Old 02-24-2014, 06:46 PM   #5
Rewards Points: 3,416
In that case tear it out and replace it,as it's in pretty rough shape.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 02-24-2014, 07:22 PM   #6
Painting Contractor
rbriggs82's Avatar
I don't think there's much worth saving there. Tear it out and start over, or just leave it as is. Otherwise you're just throwing good money after bad.
-Ryan
ParagonPainting.com
Facebook |Google+ |Twitter
rbriggs82 is offline   Reply With Quote
Old 02-24-2014, 08:42 PM   #7
landfillwizard's Avatar
Rewards Points: 502
From what i see, you definitely need to start over. If you have heaving and settlement, You should probably redo the drainage under the floor. the best bet would be to dig out at least 8" of the subgrade and replace with 2 lifts of crusher run stone. Rent a vibratory tamp and compact the stone as much as possible. Also make sure there is positive drainage away from the floor. If you have to, install drainage tile around the inside of the footer and either day light it or place a sump to get rid of the water. It might cast you more money but get a concrete contractor to pour and finish your floor. Ask for references and get several bids.
landfillwizard is offline   Reply With Quote
Tags
concrete , fix , floor , garage , patch
Concrete garage floor breaking off at entrance glampman Concrete, Stone & Masonry 2 08-25-2012 08:35 AM
Concrete garage floor cover is peeling hickspn General DIY Discussions 6 01-12-2011 10:21 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
