Help With Garage Ceiling Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 09:52 AM   #1
Help with garage ceiling joists
Hey all, I'm new here and looking for a bit of advice. I have a detached garage that is 26'x28'. I am looking to make some upgrades to it but need to figure out how to make the framing right first. It has a few ceiling joists that are 2x6 and appear to be one piece of wood running the whole length of the garage (26 foot). They are 52" on center. I know that's basically not good enough for anything. Here are some pics:
The joists are braced to the rafters in 3 places along their span. Right now what I'm looking to do is put in new garage doors and automatic openers. So I will definitely need a new joist on which to hang the powerhead for the openers. But if I'm looking to insulate and finish the ceiling in the future I will need a bunch more joists. What would be my best options for this? Thanks.
EKennett is offline   Reply With Quote
Old 04-26-2010, 11:22 AM   #2
2x's in place are merely rafter ties, holding the walls together to prevent them spreading out
I don't even think #2 grade 2x12's will span 26'
You would probably need a beam down the middle to support ceiling joists
Putting up drywall & insulation ?
Local lumber yard could run the numbers for spans & give you options
Replace or sister saging garage joists Billup Building & Construction 24 10-15-2015 11:02 AM
Raising overhead joists in my garage. Is this a good idea? jpearson311 Building & Construction 60 06-06-2012 08:25 AM
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 03:01 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
