Help With Gable Dorm - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 04:25 PM   #1
Help with Gable Dorm
I'm new to framing and I need help with framing a gable dormer. The pitch of the main roof is 5/12. The pitch of the gable is 6/12. The width of the dormer is 4 feet inside. The height of the dormer wall is 7ft-2in. I need to know how to frame the gable roof of the dormer. Any help will be great. Thanks.
jweston144 is offline   Reply With Quote
Old 11-13-2010, 06:38 PM   #2
kwikfishron's Avatar
Rewards Points: 806
Sheet the roof, set the ridge, snap the valley, and fill in.
What happened to your framer?
kwikfishron is online now   Reply With Quote
Old 11-13-2010, 07:12 PM   #3
jlhaslip's Avatar
Rewards Points: 2,776
What do you need help with? Laying out and cutting the rafters?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-13-2010, 08:22 PM   #4
joed's Avatar
Rewards Points: 13,322
Roof Framing 101
More roof framing
Old 11-13-2010, 10:42 PM   #5
Need Helpl with Gable Dormer
I need to know how to build the ridge of the gable dormer and how to connect the gable dormer with the main roof (the valley).
Old 11-13-2010, 10:44 PM   #6
I am the owner/framer. I need help to set the ridge and snap the valley. I cannot figure out how to do it.
Old 11-14-2010, 02:50 AM   #7
Framing Contractor
What size rafters and ridge are you using? Can you take a picture from the front of the dormer looking back so we can see the framing of the main roof where the ends of the dormer plates hit?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-14-2010, 02:53 AM   #8
Framing Contractor
Why are your rafters on spliced on a kneewall and not one length?
Joe Carola
Old 11-14-2010, 10:56 AM   #9
The rafter of the gable dorm is 2x4 and the ridge is 2x6. Here are more photos:
http://i52.tinypic.com/imq7ih.jpg
http://i51.tinypic.com/mawk7t.jpg
The closest dormer in this photo shows my attempt in building the top of the dormer (2x6 ridge and 2x4 rafter). I don't know how to build the valley between the dormer and the main roof.
http://i54.tinypic.com/29lyb8i.jpg (front close-up of one of the dormer)
http://i51.tinypic.com/2a59go.jpg (rear close-up of one of the dormer)
http://i56.tinypic.com/2vnkmxh.jpg (looking out from the rear of the dormer)
Old 11-14-2010, 04:44 PM   #10
Registered User
Rewards Points: 526
Get the fascia and sheathing on the main deck first, a lot easier walking around the dormers. When you sheath up to the blocking, drill or notch them if a vented attic as per local B.D.
Any snow load?
Gary
Old 11-15-2010, 04:39 PM   #11
Framing Contractor
How did you frame the rafters on the first one in that one picture?
Joe Carola
Old 11-15-2010, 05:16 PM   #12
Rewards Points: 806
As GBR said your next step is to get the roof sheeted on the dormer side anyway. Then you set your dormer ridge to the sheathing, cut the common rafters on the dormer, string and cut the tails of those rafters. Then string line the rafter tails to see where they intersect the main roof. Mark that and snap a line between that mark and where the dormer ridge hits the main roof then frame to that line. I lay some 1x back from the line for the valley rafters to sit on, reinforcing the sheathing.
Tags
gable dormer
Do I need the gable vents bjakeski Roofing/Siding 4 08-17-2010 05:17 PM
Installing gable vent from inside attic? RDS Roofing/Siding 0 03-12-2010 01:13 PM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 12:55 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 07:32 AM
Changing gable over hip roof to gable end billybarty Building & Construction 2 03-11-2008 11:20 AM
