Old 06-17-2011, 11:10 AM   #1
Help with front porch
Hello:
We have a basic front porch with three steps and a railing; its made of pressure treated pine. The "floor" portion before the door is for some reason nothing more than cheap, rotten-looking luan but the beams underneath are apparently solid. The porch itself is solid. I originally wanted to replace or lay over the flooring, but we made the mistake of painting the steps and the railings and learned the hard way that pressure treated pine does.not.hold.paint. The steps look terrible. I would like to know if we should (a) just replace the whole porch with plastic lumber or maybe rebuild it with cedar (b) just lay a new floor since that is the worst part - maybe tongue in groove composite decking? I would like a cost effective solution - any ideas how much it would cost us to redo it? Husband is not too shabby with carpentry - is this something we could do ourselves?
Thanks, Carmen
Last edited by portiafimbriata; 06-17-2011 at 11:22 AM. Reason: couldn't attach picture
portiafimbriata is offline   Reply With Quote
Old 06-17-2011, 03:08 PM   #2
Drywall contractor
If the framing is solid, I'd just replace the decking and rails. Composite material is more expensive, but lasts virtually forever. You would have to estimate the amount of material to figure the cost. Can't do it from the picture, and prices vary from area to area......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 01:58 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 01:31 PM
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 05:16 PM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 04:12 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
