Help Figuring Siding Coverage - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 06:20 PM   #16
Indentured Servant
House taken from the dock. All new windows on this side. Anderson 400 series, and 3 sliding patio doors, the one on the main level is a double glider.
jackpine is offline   Reply With Quote
Old 08-31-2011, 06:26 PM   #17
kwikfishron's Avatar
Rewards Points: 598
You can get more of that. That notch on the back doesn’t have to be there to match the look.
kwikfishron is offline   Reply With Quote
Old 09-01-2011, 07:50 AM   #18
I ask the impossible!
Rewards Points: 692
So it looks like it has a full first story, the second story is like a finished attic and you have a walk-out basement? And the walk-out basement is finished with brick, so you'd be starting the siding above that?
There is a lot of window area, so I'd say you need to measure the window sizes to get an idea how much area you need to cover. Plus when I guessed 10' height, it was just that - a guess, even if it was a reasonable approximation it would be more accurate if there were actual numbers.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 09-01-2011, 08:07 AM   #19
Indentured Servant
Walkout wall will be done in ledgestone about 4 feet up, the rest sided. I know now that I do not have enough of the redwood to cover entire house so I am exploring possibilities. One is to cedar shake the gables. Another is to side one entire side, the back side of the house that is against the tree line with similar reveal cedar siding and staining it the same as the redwood. I need to test the stain with the two woods to see how it matches. I don't have any exterior window trim purchased yet, thinking of just using 1x4 or 1x6 cedar and will pick some up today to see how that stains out too. Anxious to get started.
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
