#1 |
Help: Drilling into concrete or stud?
Hello everyone,
I'm new to the whole handyman world. I was installing a closest organizer in the basement closest. I used a stud finder to locate the studs. I found one and as i was drilling the screw would stop half way and not go any further. I attempted to drill in the bottom portion of the bracket and it screwed in fine (ie into the stud) but the top portion wasnt going anywhere. I pulled out the screw and noticed the tip covered in white sand like substance. So my question is could i have been drilling into concrete? My only worry is that i was drilling into a water or gas pipe. When i pulled out the screw i didn't see any water leaking or smell gas of any kind. Any help will be greatly appreciated. Thanks in advance. |
#2 |
the Musigician
Hi and welcome to the forum.
Does the closet have drywall on it? Perhaps your screw hit a metal plate protecting electrical wire from your screw! I'd attempt to relocate the organizer to a slightly higher or lower height, regardless of what you're hitting. Do not attempt to drill. DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Thanks for your reply. I did relocate one of the brackets but left the first one there. i pluged the hole with a plastic wall anchor and left the initial bracket. If i did hit a water or gas pipe would i have known right away?
#4 |
And yes the closet has drywall. Thanks again.
#5 |
the Musigician
Your water, gas and electric would all have a steel plate protecting them.
Hitting any of them you'd know right away I imagine.... hissing for gas, a shower for water, and a shock, or power disappears somewhere in the house for electric. DM
#6 |
Ok thanks. Makes me feel alittle better. Thanks again.
#7 |
the Musigician
It MAY also be that your 2x4s are flat on the basement wall, and yes, you DID hit the concrete.
Did you go in as far as a 2x4 is thick? DM
| Display Modes | |
| How To Keep Your Concrete Mixer Driver Happy | Mort | How To Guides | 36 | 08-05-2012 11:43 AM |
| Recommendations on appropriate drill for drilling into concrete floor | silvergs | Building & Construction | 8 | 10-27-2009 06:30 PM |
| Drilling into concrete walls | klycklama | Building & Construction | 4 | 02-09-2009 04:07 PM |
| Drilling Through Concrete Wall | rjordan392 | Building & Construction | 8 | 07-23-2008 07:30 PM |
| Wood to Concrete without Drilling | MattStata | Carpentry | 1 | 04-19-2006 05:16 PM |
