-   -   Help: Drilling into concrete or stud? (http://www.diychatroom.com/f19/help-drilling-into-concrete-stud-70984/)
rev1976 05-11-2010 12:39 PM
Hello everyone,
I'm new to the whole handyman world. I was installing a closest organizer in the basement closest. I used a stud finder to locate the studs. I found one and as i was drilling the screw would stop half way and not go any further. I attempted to drill in the bottom portion of the bracket and it screwed in fine (ie into the stud) but the top portion wasnt going anywhere. I pulled out the screw and noticed the tip covered in white sand like substance. So my question is could i have been drilling into concrete? My only worry is that i was drilling into a water or gas pipe. When i pulled out the screw i didn't see any water leaking or smell gas of any kind. Any help will be greatly appreciated. Thanks in advance.
DangerMouse 05-11-2010 12:54 PM
Hi and welcome to the forum.
Does the closet have drywall on it? Perhaps your screw hit a metal plate protecting electrical wire from your screw!
I'd attempt to relocate the organizer to a slightly higher or lower height, regardless of what you're hitting.
Do not attempt to drill.
DM
rev1976 05-11-2010 01:07 PM
Thanks for your reply. I did relocate one of the brackets but left the first one there. i pluged the hole with a plastic wall anchor and left the initial bracket. If i did hit a water or gas pipe would i have known right away?
rev1976 05-11-2010 01:08 PM
And yes the closet has drywall. Thanks again.
DangerMouse 05-11-2010 02:06 PM
Your water, gas and electric would all have a steel plate protecting them.
Hitting any of them you'd know right away I imagine.... hissing for gas, a shower for water, and a shock, or power disappears somewhere in the house for electric.
DM
rev1976 05-11-2010 02:15 PM
Ok thanks. Makes me feel alittle better. Thanks again.
DangerMouse 05-11-2010 02:25 PM
It MAY also be that your 2x4s are flat on the basement wall, and yes, you DID hit the concrete.
Did you go in as far as a 2x4 is thick?
DM
rev1976 05-11-2010 02:47 PM
I think so. It's an old house with no insulation. Just drywall, studs and the wall.
