Help With Deck Design - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2007, 08:53 PM   #1
Help with deck design
Here is a pic of the back yard of my house, and a quick idea I put together with some software - its not to scale yet, but want to get a good idea on what im not thinking about...
Deck will be 12" off ground, then the raised portion with hot tub will be 36" tall so the hot tub will be flush with the deck.
Thanks for any ideas!
rhwimmers is offline   Reply With Quote
Old 07-22-2007, 08:54 PM   #2
If you were to rotate the CAD drawing 90 degrees right, that is how i plan it to fit in..
Old 07-23-2007, 10:11 PM   #3
robertcdf's Avatar
Seems to be fine... What do you need help with? Ask away and we will fill you in.
robertcdf is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 10:37 PM
Wholesale IPE or Cedar Decking free deck design woodybill Carpentry 1 01-28-2004 11:57 PM
