Help-Cutting A Load Bearing Stud For A Dog Door!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 01:19 PM   #1
Help-Cutting a load bearing stud for a dog door!!
I installed a small dog door a couple of years ago. I installed it as close as I could to the back door. It ended up being between the door frame and a stud that is 5 1/2 inches away. The small dog door fit perfectly between the 2. Now we have a bigger dog, I bought the next bigger door, but to install it in the same location I will have to cut the stud that is 5 1/2 inches from the door frame. What is best option here? I think framing the new dog door would be easier than trying to replace the Hardy Board that I cut for the original door.
TangoHotel is offline   Reply With Quote
Old 02-16-2013, 01:42 PM   #2
Rewards Points: 12,830
Really should be opening up the wall from the inside and adding a header.
Easy enough to cut the siding with a 4-1/2" right angle grinder and a diamond blade.
Hardway (02-16-2013)
Old 02-16-2013, 01:50 PM   #3
I am not a carpenter. Would a single 2x4 across the top be ok? I need an additional 2 inches or so. About the width of the stud.
Old 02-16-2013, 01:57 PM   #4
We do not have a picture, no dimensions, so it's anyone's guess.
I would at least double it up and install jacks on the sides.
http://www.bing.com/images/search?q=...electedIndex=7
Old 02-16-2013, 02:06 PM   #5
Old 02-16-2013, 02:12 PM   #6
No picture came up.
Would be interesting to see how you plan on trimming this out on the outside to keep water out.
Old 02-16-2013, 02:19 PM   #7
I think the picture will work now. As for water/weather-the door is under a covered patio. It has not been an issue for the smaller door. There are vinyl flaps on both sides of the opening. The opening is also 6 inches higher than the patio on the outside.
Old 02-16-2013, 02:21 PM   #8
The hole/opening needs to be 8 1/4 x 13 1/2.
Tags
dog door , stud
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
lnstall 24" pocket door in a load bearing wall Pilswon Carpentry 3 01-13-2011 05:01 PM
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 11:31 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
