HELP! Concrete Pad NOT Level - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2007, 07:29 AM   #1
Angry
HELP! Concrete Pad NOT level
I had to have a concrete pad removed a second time (see previous post: Concrete Pad)
They poured the third pad last night. I told them one side of the pad sloped into the garage but they said not to worry.
Went to wet down the pad this morning and guess what - the water came streaming into the garage! The area that slopes into the garage is about 10' x 3.5' so it's not a big area.
What can they (I) do?
Q1: Would a 'patching compound' be exceptable? I would think a thin layer of 1/8" to a 1/4" could be blended to the garage side of the pad.
Q2: Do I demand they re-do again!?!
happy 51 is offline   Reply With Quote
Old 06-20-2007, 08:12 AM   #2
RippySkippy's Avatar
Q2...
RippySkippy is offline   Reply With Quote
Old 06-20-2007, 08:33 AM   #3
My Q2 was do I demand that they tear out the pad and re-pour a new hopefully level one?
Old 06-20-2007, 08:41 AM   #4
Rewards Points: 5,336
At what point will you decide these guys are incompetant ? Two slabs ago these guys would have been a memory.
Ron
Old 06-20-2007, 10:07 AM   #5
Go with response 2. If you're able, demand that you or someone of your choosing inspect the form work before pour. It's not that big of an area to run a level around and verify which way the water will flow....
Oh and by the way...Ron is right.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Level finished concrete generaldorf Building & Construction 5 01-15-2007 03:38 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
