Help. Concrete Overpour Solution Needed. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 05:01 PM   #1
Help. Concrete overpour solution needed.
Had a ground rough replaced in a basement and poured concrete back in. Flooring installer came behind me and over-levelled the floor, in an effort to prep it for vinyl tile. He disappeared.
Now, I need to find a way to lower the level of the concrete in some areas... a means of sanding it down if you will.... Can anyone offer ideas on how this can be accomplished?
thank you
brokenhammer is offline   Reply With Quote
Old 08-09-2011, 05:24 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can rent floor grinders/planers. Some attach to a vacuum for dust collection and control.
XXX
Old 08-09-2011, 07:50 PM   #3
Concrete & Masonry
Rewards Points: 530
You're not going to like this, but probably the easiest & cheapest way to fix this is probably going to be tearing the patch out & starting from scratch.
jomama45 is online now   Reply With Quote
Old 08-09-2011, 08:25 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually...I would say that would be the best-bet.
XXX
Old 08-10-2011, 09:47 AM   #5
AGWhitehouse's Avatar
Me Three!
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 02:01 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Laid Down Concrete Incorrectly overzealous Building & Construction 6 06-03-2008 07:44 PM
