Help On Clapboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2005, 06:46 PM   #1
Question
help on clapboard
i have a 5 1/2 wide clapboard..how much is 1 sq.? thanx
natto is offline   Reply With Quote
Old 09-29-2005, 08:11 PM   #2
Carpenter
DecksEtc's Avatar
1 sq. ft. is 1 sq.ft., regardless of the material you use.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 09-29-2005, 11:07 PM   #3
Code:
[QUOTE=DecksEtc]1 sq. ft. is 1 sq.ft., regardless of the material you use.[/QUOTE
Probably 1 inch overlap so your 5.5 becomes 4.5=.375 ft sq/ lineal ft. So 100 sq ft./ 266 lineal. So 266 lineal ft. I'm assuming clapboard is the same as what i call lap siding. Probably should figure some waste on the bottom line, 10%. ]
K2eoj is offline   Reply With Quote
Paintbrush or sprayer for clapboard house exterior dvarga Painting 7 01-04-2009 01:12 PM
Painting Clapboard BilHam Painting 4 06-07-2007 10:06 PM
Vinyl siding over wood clapboard C&D Building & Construction 3 09-13-2006 09:14 PM
how do i measure clapboard? natto General DIY Discussions 2 09-30-2005 07:55 AM
nails to use for exterior clapboard dvarga Painting 1 07-31-2005 03:10 PM
