-   -   help on clapboard (http://www.diychatroom.com/f19/help-clapboard-1076/)
natto 09-29-2005 06:46 PM
help on clapboard
i have a 5 1/2 wide clapboard..how much is 1 sq.? thanx
DecksEtc 09-29-2005 08:11 PM
1 sq. ft. is 1 sq.ft., regardless of the material you use.
K2eoj 09-29-2005 11:07 PM
Code:
[QUOTE=DecksEtc]1 sq. ft. is 1 sq.ft., regardless of the material you use.[/QUOTE
Probably 1 inch overlap so your 5.5 becomes 4.5=.375 ft sq/ lineal ft. So 100 sq ft./ 266 lineal. So 266 lineal ft. I'm assuming clapboard is the same as what i call lap siding. Probably should figure some waste on the bottom line, 10%. ]
