Help With Building Soffit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-09-2014, 12:08 PM   #1
Help with building soffit
I've just framed around the I-beam and I plan on installing closet doors just in front of it because the doors are for an opening measuring 78 1/4 - 78 3/4. The height of the beam is approximately 69". There will be four bi-folding doors installed and each pair will be 72" wide with a small dividing wall in between.
Now I need to close in my ductwork and put in a frame for the closet doors. What is the best way to do this? Ideally I'd like to come straight out from the beam and up to the joist, but this would pose a problem when trying to secure the closet door rails when the studs are spaced 16" on center.
Any ideas?
Dazman is offline   Reply With Quote
Old 02-09-2014, 06:41 PM   #2
I think I figured it out.
The Following User Says Thank You to Dazman For This Useful Post:
oh'mike (02-09-2014)
Running electrical to a out building J Bar L Electrical 6 09-19-2012 12:45 AM
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 09:18 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
Attic, insulation, and soffit... Bill7 General DIY Discussions 4 08-09-2010 10:16 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
