Help Building A Partial Wall... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2014, 07:25 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Help building a partial wall...
This wall is going to be basically only to support cabinets.
I have to reframe this wall that connects the living room and kitchen. It's going to have a bar top on the lower portion, and the upper portion will have cabinets hanging from it.
The left side of the wall will be a full wall to a width of approximately 12" to serve as a plumbing chase for the upstairs bathroom. On the right side, the upper wall will be only about 20" tall to support the upper cabinets. It will be attached to the full wall on the left, and it will be floating on the right side.
What's the best way to construct the upper portion so that it will support the weight of the cabinets? Should I use some kind of hardware other than nails?
Thanks in advance.
Journeyman Plumber
Old 02-08-2014, 05:30 AM   #2
DIY staff
Rewards Points: 7,174
If I have the picture in my head---you have a knee wall below to support a counter top---attached only at one end----
Then above--a hanging short wall section---once again attached to the wall only on one end----
The big deal on the upper end is the loose,unattached end--it can get out of plumb easily when you hang cabinets on the face of the partition.
Is the cieling opened yet? If there is a way to attach a 2x4 to the ceiling joists ,on the loose end, so you have a rigid end piece----then build the little upper section--
Slide the section up between the wall and your stiff new 2x4 --screw the section to the ceiling joists and the wall/2x4 stiffener----that would be strong and fast.
How's that for 5 A.M. without any coffee
Old 02-08-2014, 11:31 AM   #3
Doing it myself
Alan's Avatar
Sounds like you have it pictured right. I was planning on stiffening the loose end both top and bottom the way you suggested.
When I assemble the upper portion should I use something other than nails to make sure it stays together?
Should I use something 1/4"x 3-1/2" lags to attach the top plate to the ceiling?
(sorry to make you track down the thread. I've been working days and nights and my brains are fried too. Should have provided a link.)
Journeyman Plumber
Old 02-08-2014, 02:01 PM   #4
Framing Contractor
Rewards Points: 118
You could use some long timberlocks (lags) into the framing there. It would also be nice if the end stud on that upper section could extend up through the ceiling as far as possible. Lind of the reverse of how we tie in knee walls through the floor usually.
sixeightten is offline   Reply With Quote
Old 02-08-2014, 03:32 PM   #5
Doing it myself
Alan's Avatar
I've got 2x12 floor joists, so I can run that end stud all the way to the subfloor. It's under a cast iron tub too, so I may even be able to partially secure the top to the subfloor from below.
If I frame this floating partition with nails, do I have to worry about them pulling apart, or should I use some kind of screws?
Journeyman Plumber
Old 02-08-2014, 05:31 PM   #6
AHH, SPANS!!!
Rewards Points: 1,166
In general nails work best at the shear and screws for pull out but get structural screws and they're the best of both worlds
hand drive is offline   Reply With Quote
Old 02-08-2014, 05:39 PM   #7
Doing it myself
Alan's Avatar
Is there anything made by GRK that would work? I used their stuff to hang the cabinets on the other side of the room and I was impressed with them.
Maybe these : http://www.grkfasteners.com/index.php/en/products/rss
Journeyman Plumber
Old 02-09-2014, 07:59 AM   #8
AHH, SPANS!!!
those grk are the screws to use. for volume you should be able to use 2 1/2" or 3" screws # 8 or #9 and not need the bolts. just add screws at every joist- 16" etc...
the screws are needed on the hanging wall portion only imo, and even the 3 1/8" trim screws would work as they are the size of a normal nail but with a smaller head.
The Following User Says Thank You to hand drive For This Useful Post:
Alan (02-09-2014)
Old 02-09-2014, 12:02 PM   #9
Doing it myself
Alan's Avatar
Thank you
Journeyman Plumber
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 08:36 AM
Building partition wall behind base cabinets bluefitness Building & Construction 3 11-09-2010 06:49 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Building a 1/2 wall in a basement? BowDown Building & Construction 1 07-27-2009 02:13 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
