Help With Building A Loft In My Garage Please - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 09:24 PM   #1
Help with building a loft in my garage please
I have a 2 stall detached garage. I am looking to make a loft/ second floor for storage. the garage is 24 feet wide and 20 feet long. i currently have a center beam made up of 4 2x6 nailed and bolted together and supported by a 6x6 pressure treated post on either end. i want to to build it with no center support and was wondering if this wood work. Somebody told me to make roof trusses. the rafters are 2x6s. he said to run a 2x6 across one side to the center support. come in 5 feet and run a 2x4 stright up and then a 2x4 diag to the rafters. attach them using a nail plate and then run a 2x4 across the top about 6.5 feet above the floor so i have room to walk. use plywood as the floor. just was looking for some help.
thanks
shawn
ps i know using a laminated beam wood be best but not really interested in spending 600+ dollars for beam.
redsox1918 is offline   Reply With Quote
Old 09-02-2011, 09:33 PM   #2
As a firefighter for 21yrs. Don't use Gusset plates. I have 3 years of rehabilitation and scars on 40% of my body because of them. I still fight to be first and to save.
jpalmos is offline   Reply With Quote
Old 09-02-2011, 09:38 PM   #3
sorry to hear about and let me say thank you for what you guys do. My grandfather and me sister in laws husband is a firefighter. what would i use if not the gusset plates?
Old 09-03-2011, 01:02 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Well, where does one begin?
I guess by saying that you really ought to have this designed to code, even if you are not in an area that requires it.
You could throw together any assortment of lumber-like sticks and call it good or do you want to have a well made and safe loft storage area?
My suggestion is to find a pro to design it for you then you can go to DIY Town, on the project, as it were.
Andy.
AndyGump is offline   Reply With Quote
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Building in a loft space sgorel Off Topic 3 05-24-2010 06:50 PM
flooring choices for loft in garage into Flooring 0 02-28-2010 02:19 PM
Building a loft chitownphoto Building & Construction 2 02-18-2010 03:34 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
