Old 04-20-2011, 05:09 PM   #1
Question
HELP! 80+% Humidity in my bedroom!
Ok, so we got screwed and rented an old house that is falling apart. The LL is refusing to do anything about the fact that we are dehumidifying about 2 gallons every night out of the bedroom, which is an addition. The walls and ceiling are wooden, I believe (HOPE) that it is finished cedar and the studs are exposed. This part of the house also has a flat roof and no insulation.
We live in Central Florida, where it gets unbearably hot and have a window unit air conditioner that is currently running 24 hours a day, due to the humidity increase and the temp. We unfortunately have to cut corners and cost as much as possible, but need to do something or we're going to lose our clothing and other items in that room.
Please, any information and suggestions would be wonderful.
Florida does not have a mold law, and there is no city or county code referring to air conditioning or humidity within a home, the house was built in '54, but the addition could be 5-30 years old, for all I know. We have weather stripped the casement windows and both doors to the point of barely closing and locking and have had to put every penny of our savings into this house we're renting, just to make living in it bearable, so the cheaper and easier, but more energy efficient the suggestion, the better. I know we need to insulate the ceiling, but with what? What R-factor do you recommend? With the humidity level, do I need to do any special preparation? Is there a necessity to add a drop ceiling after insulation? I'm losing my mind and sweating in my sleep and looking at a HEFTY power bill come meter reading day, that I obviously can't afford.
SinnerElla
Sinnerella is offline   Reply With Quote
Old 04-20-2011, 08:28 PM   #2
Learning by Doing
Leah Frances's Avatar
Contact your local renter's rights/housing to find out how to break your lease.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 12:19 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Humidity issues chapx HVAC 8 09-25-2009 05:11 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
