-   -   HELP With 24lbs chandellier (http://www.diychatroom.com/f19/help-24lbs-chandellier-171143/)
Bigd3129 02-05-2013 05:36 PM
Installing a 24 lbs Chandeller. My question is I mounted the chandellier to a Hook that I screwed into the joist above my living room. I don't know the rating load on this hook. Scared of it failing down its a $1000 fixture and weighs 24lbs. It's been up for 24 hrs now. Should I be worried, it's seam solid it can tug on it and seams pretty strong he r some pics
joecaption 02-05-2013 05:59 PM
Since no one know what the hook even looks like hard to say.
Post a picture.
Should have been mounted to a heavy duty box to make the wiring connections.
Bigd3129 02-05-2013 06:02 PM
My iPhone won't let me load the pics,I bought the biggest hook they had & I'm not mounting it to my electrical box
hand drive 02-06-2013 11:20 AM
if you mounted the hook directly center up through the joist then it is most likely plenty strong, I'm assuming you bought an over 100 lb hook.
danpik 02-06-2013 02:39 PM
What did the manufacturer say about mounting it? This is the best method to use.
Joe Carola 02-06-2013 08:01 PM
You ask if you should be worried 24/hrs later. Use a little bit of common sense and take it down and figure out the right way to hang it.
What good does it do you hanging on a hook that you know nothing about worrying about there being a chance of it falling???
Figure our the right way to do something BEFORE you do it...
Doesn't anyone have common sense anymore...
