Hello, ... Need Some Help, With DIY Project. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 03:35 PM   #1
Thumbs up
Hello, ... Need some help, With DIY project.
I am currently in the Process of building a personal snow plow on wheels. Wheels, the size of the average Wheelbarrow Wheel. My Problem, that I am hoping you all can help me with, is I need the Wheels AND THE SPINDLES and the attaching points. Can't seem to find this stuff anywhere - I need the Wheels, Spindles AND the Hardware to attach it. Please help me find this so I can get My Project on wheels. Thanks so much.
EdgarThree is offline   Reply With Quote
Old 01-16-2013, 03:41 PM   #2
Rewards Points: 13,266
Northern Tools should have everything you need.
By the time you buy all that you could have bought one just as cheap.
http://www.amleo.com/product.aspx?p=...0with%20wheels
EdgarThree (01-17-2013)
Old 01-16-2013, 03:47 PM   #3
Sorry, Thanks but not close to what I want.
... I have always thought of one that I have never seen, so, I figured I will build it - And besides those wheels on that device, will bury and make it useless, where I need to use this device I am thinking of, I need way bigger wheels. But again thanks.
Old 01-16-2013, 05:01 PM   #4
Registered User
Rewards Points: 5,212
Do you have access to a torch, or arc welder, etc.? Are you planning on bolting it together? Need more info... Use a child's bicycle wheel- 9", 12" 16" etc. Many on Craigslist for free. Or, http://www.harborfreight.com/catalog...elbarrow+wheel
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 01-16-2013, 10:08 PM   #5
Unhappy
Gary
Actually I was thinking of using a simple bolting or screws to hold the Bracekets. Wheel, spindle and mounting brackets - Why is this so hard? You would think its sold as a kit of some type, But I can't find anything. ... *Frustrated*
Old 01-17-2013, 11:27 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,.... Standard wheelbarrows, of the Contractor grade use simple 5/8" round bar as the axle....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-17-2013, 11:35 AM   #7
Make this to heavy and it's going to be useless. It's hard enough to push one on snow and ice covered surface with no wheels, add all that weight and you have to over come that weight plus the weight of the snow.
The wheels are only for moving it from place to place to use it, not for when your plowing.
Old 01-17-2013, 03:18 PM   #8
Thank you all for you information and advice, ... However, what I am thinking of, is not the standard Snow Plow, ... will post pics once done. As for my problem, I have decided to use 10" Pneumatic Casters as my wheels - Again thank you for all your input. ...
Old 01-17-2013, 08:46 PM   #9
I watched the video and the guy was using the wheels for plowing. That will only work on a flat surface, and with the dry fluffy snow. This looks a little like a joke.
paintdrying is offline   Reply With Quote
Tags
spindles , wheels
Drywall project: New basement bathroom NetTractorTalk Drywall & Plaster 15 10-03-2012 01:23 PM
Troubleshooting 3 switches in one box for bathroom project Jerrys84 Electrical 11 08-01-2012 03:48 PM
My basement project - a 2 year project. HABSFAN2006 Project Showcase 14 07-12-2009 10:30 PM
Interesting Project Mcamnl Electrical 14 05-27-2009 02:13 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
