Heavy Duty Deck Framing Connectors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 01:00 PM   #1
Rewards Points: 2,240
Where can I get H.D. Framing connectors -
One's that use 4 to 6 bolts.
6 X 6 to 6 X 6 - post to beams.
Didn't find any at "Simpson".
rossfingal
rossfingal is online now   Reply With Quote
Old 10-08-2012, 01:08 PM   #2
funfool's Avatar
Rewards Points: 534
what are you attaching, is common sizing, is often used in deck construction, but also building, what is your project?
funfool is offline   Reply With Quote
Old 10-08-2012, 01:36 PM   #3
kwikfishron's Avatar
Rewards Points: 782
rossfingal
Is Simpson doesn't have what I need I have a local guy fabricate it and send it off to the galvanizer.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
mae-ling (10-09-2012), rossfingal (10-10-2012)
Old 10-08-2012, 02:17 PM   #4
robertcdf's Avatar
We usually have things custom made or we use bulk strapping if it'll get covered.
Check on powder coating vs galvanizing, sometimes it's cheaper to powder coat and in most environments it's more than enough.
robertcdf is offline   Reply With Quote
Old 10-08-2012, 02:58 PM   #5
Thanks for the replies.
Found them - local lumber yard!
rossfingal
The Following User Says Thank You to rossfingal For This Useful Post:
Old 10-08-2012, 06:52 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
You should have been able to find those in the Simpson catalog, check under CC and CCU post/column caps.
This Link.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 10-09-2012, 01:52 PM   #7
This Link.
Andy.
Thanks Andy!
Close - but, not quite what we're looking for!
rossfingal
Old 10-09-2012, 03:42 PM   #8
GBrackins's Avatar
Rewards Points: 2,108
I believe these are the ones Andy was talking about .....
http://www.strongtie.com/products/co...C-ECC-ECCU.asp
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-10-2012, 05:09 AM   #9
Thanks again for the replies!
We like "kwickfishron"s advice.
We priced that out - kind of expensive.
What we're going to use is a 90 degree metal angle - about 1/4 to 3/8's
inches thick -
at least 2 bolts through the beam and 2 through the post.
This is a retrofit.
rossfingal
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Framing a whirlpool deck! MikeVila Carpentry 14 12-18-2008 12:43 AM
Tub Deck Framing FlyBoyd Carpentry 3 10-18-2008 11:32 PM
