-   -   Heavy Duty Deck Framing Connectors (http://www.diychatroom.com/f19/heavy-duty-deck-framing-connectors-159398/)
rossfingal 10-08-2012 01:00 PM
Where can I get H.D. Framing connectors -
One's that use 4 to 6 bolts.
6 X 6 to 6 X 6 - post to beams.
Didn't find any at "Simpson".
rossfingal
funfool 10-08-2012 01:08 PM
what are you attaching, is common sizing, is often used in deck construction, but also building, what is your project?
kwikfishron 10-08-2012 01:36 PM
199 Attachment(s)
rossfingal
Is Simpson doesn't have what I need I have a local guy fabricate it and send it off to the galvanizer.
robertcdf 10-08-2012 02:17 PM
We usually have things custom made or we use bulk strapping if it'll get covered.
Check on powder coating vs galvanizing, sometimes it's cheaper to powder coat and in most environments it's more than enough.
rossfingal 10-08-2012 02:58 PM
Thanks for the replies.
Found them - local lumber yard! :)
rossfingal
AndyGump 10-08-2012 06:52 PM
You should have been able to find those in the Simpson catalog, check under CC and CCU post/column caps.
This Link.
Andy.
rossfingal 10-09-2012 01:52 PM
This Link.
Andy.
Thanks Andy!
Close - but, not quite what we're looking for!
rossfingal
GBrackins 10-09-2012 03:42 PM
I believe these are the ones Andy was talking about .....
http://www.strongtie.com/products/co...C-ECC-ECCU.asp
rossfingal 10-10-2012 05:09 AM
Thanks again for the replies!
We like "kwickfishron"s advice.
We priced that out - kind of expensive.
What we're going to use is a 90 degree metal angle - about 1/4 to 3/8's
inches thick -
at least 2 bolts through the beam and 2 through the post.
This is a retrofit.
rossfingal
