Heavy Bag (aka Punching Bag) Frame Project - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 01:33 PM   #1
Heavy Bag (aka punching bag) Frame Project
Hello,
I need to build a frame that can support at least two heavy bags (punching bags). The bags will way from 100-150 pounds apiece. Due to space restrictions I am building this frame outdoors and it will span my drive way.
My plan is to purchase 3 4x4 treated lumber posts. One will be 16' wide and be the horizontal span. The two vertical posts will be 10'?.
Will 4x4 treated lumber be structurally sound or should I use 6x6? The bags will sway and vibrations from the impact of punches and kicks will transfer through out the structure. Is there a forumla builders use to determine load bearing qualities for my type of situation.
For Fastening I was going to bury 2 feet of the posts in cement. For fastening the posts I was thinking of using metal brace connectors with screws (what size?). Should I use another fastening method (bolts)? Should I use some form of cross bracing?
Thank You
Harley1 is offline   Reply With Quote
Old 01-28-2009, 01:55 PM   #2
Try to look online for swing set plans. 16' might be a stretch for the horizontal run. You may have to get some dimensional lumber and builder some type of "header".
jerryh3 is offline   Reply With Quote
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 07:46 PM
mirror frame jdwdwd Carpentry 3 03-31-2005 09:34 PM
