Old 06-02-2012, 01:39 PM   #1
Heat rating wiring
Im wiring a sauna for lights. Romex does not go high enough for the heat rating. What kind of
wire do i use?
Bailout1 is offline   Reply With Quote
Old 06-02-2012, 05:05 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Heat rating wiring
Teflon insulation?
Old 06-02-2012, 11:35 PM   #3
Heat rating wiring
No standard with a foil bairier
Old 06-03-2012, 08:53 AM   #4
MarginallyQualified
Heat rating wiring
wire do i use?
You'll need to sleeve wire through Greenfield (or conduit).
Good high temp wire can be sourced from most good appliance repair companies along with the s/s terminal ends you'll need.
hth
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 8 11-19-2011 11:45 PM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 09:18 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
