-   -   Heat rating wiring (http://www.diychatroom.com/f19/heat-rating-wiring-145725/)
Bailout1 06-02-2012 12:39 PM
Heat rating wiring
Im wiring a sauna for lights. Romex does not go high enough for the heat rating. What kind of
wire do i use?
Yoyizit 06-02-2012 04:05 PM
Teflon insulation?
Bailout1 06-02-2012 10:35 PM
No standard with a foil bairier
TarheelTerp 06-03-2012 07:53 AM
wire do i use?
You'll need to sleeve wire through Greenfield (or conduit).
Good high temp wire can be sourced from most good appliance repair companies along with the s/s terminal ends you'll need.
hth
