Heat Escaping From My New Home. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 10:07 AM   #1
Heat escaping from my new home.
My wife and I just bought a home in Nort East Ohio. It seems that the snow near the base of my home is melting a lot faster than any of the snow in my yard. Is this caused by heat escaping from the home? It is a slab home with a forced air system. The home is only 30 years old and is in very good shape. Any input will be greatly appreciated.
Bronx is offline   Reply With Quote
Old 02-02-2009, 10:21 AM   #2
Rewards Points: 5,336
Is it melting on all sides or just the sides the sun hits?
Ron
Old 02-02-2009, 10:27 AM   #3
Ron
Its on all sides.
Old 02-02-2009, 11:49 AM   #4
Registered User
Termite's Avatar
The earth under your home is certainly warmer, and the concrete slab does in fact conduct heat. I would attribute a little snow melting up against the house to either/both of those factors.
Old 02-02-2009, 12:43 PM   #5
Thanx
kctermite, Thanx. Is there anything that I should be doing or should I just live with it?
Old 02-02-2009, 01:16 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,...
Good old fashion Banking around the foundation may Help....
Old 02-02-2009, 02:09 PM   #7
Banking?
Bondo, What is good old fasioned banking?
Old 02-02-2009, 10:31 PM   #8
Bondo's Avatar
Well,...
Back in the day,..
Sometimes Tar Paper would be lathed along the bottom of the siding, folded,+ held to the ground with sticks....
Other times,... Hay Bales would be stacked tightly against the foundation/ house....
This year,...
I duct taped a heavy poly strip in a manner as the tar paper above....held down to the ground with 2x4s,... I think it helped with the drafts,+ the Oil Bill...
Problem was,... A Big Blow, blew it apart, not once but thrwice,.... I quit,... atleast 3 sides are still covered... Once the Snow covered it, the wind is No longer a Problem...
I think the plastic, with the hay bales would be the absolute Best....
Old 02-02-2009, 10:43 PM   #9
Rewards Points: 562
hay or straw bales "WILL" attract every mouse and larger rodent in the county!!!
4just1don is offline   Reply With Quote
Old 02-02-2009, 10:53 PM   #10
Registered User
Termite's Avatar
Radient rodent body heat would be attributed to a .00239% decrease in heat loss, per my super-scientific calculations. Deduct a couple points if the rodents are small.
Bronx, on a serious note, I'd just make sure the house is sealed up tight and properly insulated and heated. Other than that you probably need to learn to live with it.
Old 02-03-2009, 12:32 AM   #11
truck in more snow from the rest of the yard & don't worry about it,,, spring'll be here soon
yesitsconcrete is offline   Reply With Quote
Old 02-03-2009, 06:35 AM   #12
Thanx to all
If I put hay bales around the outside of my house my wife would kill me. I will look into it again in the spring when I can go outside without the risk of losing a finger to frostbite.
Old 02-03-2009, 06:48 AM   #13
leaf-fill'd blk plastic bags don't look too bad when plac'd alongside the fnd,,, matter of fact, they kind of compliment the school bus & white truck tire planters
Old 02-03-2009, 07:16 AM   #14
I got an idea
I can put my mother in law out there up against the wall. She has enough hot air that I could turn off the furnace.
Old 02-03-2009, 04:43 PM   #15
careful or you'll be changing your login from ' bronx ' to ' bobbitt '
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
