Headers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 10:26 PM   #1
Rewards Points: 60
headers
can you take out a header and put up two more to replace the one you took out? We are talking about a basement trying to put bedrooms in and the hearder well be in the way and there are 4x4 holding it up
any help your be great
thanks jaws
jaws is offline   Reply With Quote
Old 12-31-2011, 10:33 PM   #2
Rewards Points: 13,300
Someone would have to be on sight to look it over to tell you that one.
You do have permits for this work right?
How many windows do you have down there and how big are they.
Gary in WA (12-31-2011)
Old 01-01-2012, 08:29 AM   #3
What he said, basments with living, and especially sleeping space require an emergency exit.
Basement headers are usually not supporting anything, so it is easy to expand them. But a look-see from someone qualified would be advised.
Old 01-01-2012, 08:32 AM   #4
It seemed hard to believe someone would have used a 4X4 instead of 2 X 4's. Sounds more like it could be a coloum for floor support.
Old 01-01-2012, 08:36 AM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Is the header holding up floor joists?
Also, there must be a window in each bedroom, a minimum size per code, for a fire escape.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Sizing Headers in Older Home Thadius856 Building & Construction 4 09-02-2011 12:31 AM
Windows installed with no headers WillK Building & Construction 7 02-06-2011 02:54 PM
Door headers on non-loadbearing walls? DangerMouse Building & Construction 7 09-21-2010 04:39 PM
headers for basement doorways Railz Carpentry 3 12-15-2008 11:47 AM
Window Headers williamp Building & Construction 6 06-09-2007 09:00 AM
