Header Sizing Question..... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 04:22 PM   #1
Header sizing question.....
I am framing a window in an exterior bearing wall, but want to assure myself of proper heading sizing. Unfortunately, there are NO building inspectors or inspections where I live, so I can't turn to the local inspector for help...
The room is in a basement, 13 feet wide with first floor I joists at 16" oc spanning this distance and supported by the 2x6 basement exterior walls. ....there is a second floor and the spans are the same. The wall also supports the roof.
The ground snowload for my area is 100 psf. I want to span 4-5 feet with a new header, but can not find a span table for this snow load. Can anyone help?
To accomodate a window top height of 82", I would like to use a 2x8 header. My plan is a triple 2x8 with 2 1/2" plywood sections between them.
Thanks for the help!
Oxymoron is offline   Reply With Quote
Old 01-08-2010, 08:25 PM   #2
Remodeling Contractor
I have one, PM me and I can email it.
Old 01-08-2010, 09:13 PM   #3
Thanks!!!
Just sent you pm....
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Question Re: New Furnace and Duct Sizing DSimo HVAC 3 06-17-2008 07:24 AM
Sub panel sizing and distance question fburke Electrical 13 06-11-2008 06:33 PM
Max span for 4x8 header? MusicMan_234 Building & Construction 2 05-29-2008 12:17 PM
