Header Size For Wall Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2007, 04:39 PM   #1
Header size for wall opening
I'm planning on making an opening in a load bearing wall to open up my kitchen to the dining room. The wall is carrying the second floor joists that are running perpendicular to the wall.
The opening is going to be 9' 6" wide and I can go as deep as 2' with the header. Can anybody please tell me what kind (dimension) of header do I need to complete this project.
Thanks in advance.
firebirdbd is offline   Reply With Quote
Old 08-07-2007, 05:11 PM   #2
I would suggest 2 Laminated beams 11 7/8 with at least 3 inches of bearing on either side.
This is probably overkill but better safe then sorry.
Also don't just take my word there may be more bearing on this than you or I are aware of. Get a contractor to look it over. Most will give you advice for a nominal fee. Your other option is to get a complete set of plans and ask your local building inspector what you need.
jiggyjack is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Advice on Enlarging a Door Opening WorkOnIt Carpentry 9 02-04-2007 11:53 AM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
