Header Size Needed? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 08:38 PM   #1
Header size needed?
I need to size a header to convert a current window (32in) to a 12 ft clear opening. The wall for the header is on the main (middle) level of a three level home. The wall is an internal wall and supports one floor above (bedroom).
Mig44 is offline   Reply With Quote
Old 04-30-2012, 08:39 PM   #2
Rewards Points: 1,578
You need to get an engineer on site to provide the size header and the rest of info for this job; can't be done over the internet.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
woodworkbykirk (04-30-2012)
Old 04-30-2012, 09:37 PM   #3
Framing Contractor
This isn't a forum for sizing headers. You need to have an architect or engineer do this.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-30-2012, 09:39 PM   #4
12' is a stretch for a traditional multiple 2x header. you should be looking at lvl, steel beams or similar.
since this is the second floor, need to consider bearings below, likely down to grade. to echo what bob22 said, this isn't something to guess at. if looking at lvl, lots of lumber yards will size the beams for you if you give them some plans of what you are trying to do. most do it for free or free if you buy the lvl from them.
when you start talking middle floors of multi-story buildings, however, you may be headed for the consultation of a structural engineer.
itsnotrequired is offline   Reply With Quote
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 07:22 PM
header size billbagwell Remodeling 1 11-10-2010 08:12 PM
header size? sharp Building & Construction 6 11-30-2009 07:27 PM
Garage door header size Bogey0345 Carpentry 12 11-29-2009 06:21 PM
Header size question BimmerRacer Carpentry 18 03-01-2009 07:51 PM
