Header Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 04:51 PM   #1
Header size
I am getting ready to build a cabin and the wife wants double hung windows in the bedrooms. I am trying to figure out the minimum size for headers. I figured if I use some type of engineered product I could go smaller . She wants the windows as far off the floor as possible (don't know why). I am doing 2 x 6 construction with a 50 Lb snow load. The bedrooms are upstairs and are on the weight bearing wall. The windows she likes are rough openings W 42 1/2 L 56 1/2.
warnerww is offline   Reply With Quote
Old 01-26-2010, 04:58 PM   #2
I use 2x10's or 2x12's & put the header right up against the top plate
I also do a 2x6 wall & use an insulated triple header
Old 01-26-2010, 09:02 PM   #3
Registered User
Rewards Points: 5,516
Depends on the roof span, 2x6's may work with 50# snow, Page 2: http://www.colonie.org/forms/building/bdspanab.pdf
Notice the jacks on each side. Sounds like you have egress: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
Be safe, Gary
Old 01-27-2010, 10:48 AM   #4
I am not really looking for a specific ( you can use this at this size). What I am looking for is different products other than standard lumber . I was wondering if someone out there made something different that could stand up to a higher load in a smaller size ( like a steal header with nailing brackets). Guess not oh well I guess it will be lvl or standard lumber. Thanks guys.
Header Size Seyamr Building & Construction 5 01-28-2010 11:13 AM
What size header is needed.... mulhollendm Building & Construction 2 11-18-2009 02:34 PM
Header size question BimmerRacer Carpentry 18 03-01-2009 07:51 PM
Header size for 12' opening (not load bearing)? DIYMom2 Carpentry 1 09-07-2008 04:07 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 05:11 PM
