Header Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 10:43 AM   #1
Header Size
I am looking to replace twin windows with a sliding patio door 60 68. I have 86" from floor to ceiling (rough). Is that enough height? what size header will i need to support the 2nd floor above this load bearing wall?
thanks
Seyamr is offline   Reply With Quote
Old 01-21-2010, 05:43 PM   #2
Registered User
Rewards Points: 4,888
Find out the height and width of the rough opening for that particular door before you start. Box stores sell some different ones than window companies. This on your header, also listed is number of jack studs supporting on each side:
http://www.burlington.org/Building08/Spans.pdf Check with your local Building Department, they may be different.
Be safe, Gary
Old 01-21-2010, 07:19 PM   #3
no it is not enough height
Old 01-27-2010, 11:57 PM   #4
Can the two 2x4's that make up the top plate above the header be replaced in that section of the header, so that the header 2x8 would fit. ? Wood replacing wood.
Old 01-28-2010, 08:11 AM   #5
2x8 is to small for a 60" opening
Old 01-28-2010, 12:13 PM   #6
Did you look at the PDF chart link posted ?
It lists the sizes needed depending upon width of the house & loads
How wide is the house ?
Garage door header size Bogey0345 Carpentry 12 11-29-2009 07:21 PM
What size header is needed.... mulhollendm Building & Construction 2 11-18-2009 03:34 PM
Header size question BimmerRacer Carpentry 18 03-01-2009 08:51 PM
Header size for 12' opening (not load bearing)? DIYMom2 Carpentry 1 09-07-2008 05:07 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
