Header Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2008, 05:24 PM   #1
Header size?
Hi to all, I'm a new member here And like it alot.
I Have 112 inch long window on ranch house and like to add second floor. I dont know what kind of header is there I dont think would be good enough to support second story.
What kind of header it would need and with single or dbl jack stands (if you call like that) that header sits on?
Thanks.
ptcamaro is offline   Reply With Quote
Old 03-30-2008, 10:27 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
That's not a straight forward answer.
Is this a simple wall with a floor load, wall load, and a roof load?
What are the dimensions of the house? Is there a center bearing wall? What will the floor be covered with? Hardwood weighs more than carpet. Will there be an attic above that? Will the attic have a floor? What style of roof are you going to add. A hiproof shares the load differently than a gable roof. What is the rise of the new roof? What part of the country do you live in? Does snow load need to be added as well?
Basically anything that you can think of needs to be part of the equation. Many local lumberyards offer load calculations for free. Give them a shot, they know all the questions to ask.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-30-2008, 11:23 PM   #3
It is a simple wall with floor load roof load and wall load. 26x36 house , there is center wall bearing wall 36 ft long. It is in northeast. Attic will not have floors and roof is hip roof.
Old 04-01-2008, 07:34 AM   #4
I have gas!
I added a bay window with a 90" opening (1st floor of a 2 story house tributary of 6', hip roof). I used a double 1.75x9.25 lvl header. When I pulled out the old 108" picture window, I found no header was installed. I'd guess that you would need a double 1.75x11.25 lvl header at a minimum. What size header is in there now.
Old 04-06-2008, 10:01 PM   #5
unless your going to stack loads, meaning same size header over existing header, transfering loads down studs and cripples rather than on header
you better get an engineer or equal to spec out a header also you need a minimunm of three inches of bearing sometimes four depending on loads. do it right the first time
jason h is offline   Reply With Quote
Old 04-06-2008, 11:34 PM   #6
Wow there was no header and it was allright with the second floor weight?
There is 4x4 heade right now, And if I put 4X8 on top of it , it should be allright, Right?.
Or take the 4x4 out and put 4x10 and stack it with 2x4 like top plate to fill the gap?
Old 04-07-2008, 07:17 AM   #7
I have gas!
You definitely need engineered lumber for that span. Go to your local lumberyard and have them spec it. Mine does does that service for free. They will also be able to spec out the bearing.
Old 04-07-2008, 07:36 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Your best bet, especially because you are considering adding a 2nd floor over that, is to go to a lumber yard/building supply house, that specs out dimensional lumber. Have them spec out the proper header size, and purchase the header stock from them. Have them print out their spec sheet, that shows their calculations and load info. You will need to show that to the building dept later on, when you go to add that 2nd floor. It will show them that there is the proper structural framing there, to carry the 2nd floor.
- Build Well -
Old 04-07-2008, 07:42 AM   #9
Thanks guys.
Old 04-07-2008, 03:18 PM   #10
Rewards Points: 5,336
While the window is 112 " long it doesn't mean that's the span. If the widow is made up of individually mulled units there might be load bearing framework between the units and a series of smaller headers over the top.
Since you need an arrhitects plans for this anyway, it should be taken into consideration when the plans are drawn up. All the first floor structure will need to be surveyed for the project.
Ron
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
what kind of header rhinester Carpentry 9 03-03-2008 09:34 AM
Help determining header size Griffith.N Building & Construction 15 10-03-2007 05:40 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
